iFrame / Website Module not working
Hi there,
I just tried to get a Social Media Widget via iFrame embed code running on my Xibo system. But whatever I’m trying to do - whether to use object, embed or javascript embed, I just see a white space and nothing loads. The funny thing is, it’s working in the layout mode. But here there’s an error message “This layout contains elements just visible in the player”. Same with the native website module.
Does anyone know what I can do to fix this? I’m on Xibo Version 2.3.5.
Thanks for any hints or help!
Which OS are you using?
Android/Windows/WebOS/Tizen ?
By fact i do know that widgets in iframe is partially working in Android if it works 100% in Windows. Also a side-note for windows, Xibo is always using Edge as browser.
