Icons for Media Types in Region Timeline
How to enable icons instead of text for media types in “Region Timeline”. Previous versions of CMS used to have that by default. That’s a lot easier to choose for me.
Also, there are media items like web-page which I use very frequently than others for e.g “counter”, I would like to move “Web-page” to top and move “Counter” at the very last. How do I change their positions in the list ?
thanks
btech.
There aren’t options to change either of those things.
You can disable modules that you don’t use - eg Counter - so that they aren’t shown in the list at all. You do that in the Module configuration section.
