I want to know how to resolve error messages
System.NullReferenceException: オブジェクト参照がオブジェクト インスタンスに設定されていません。
場所 XiboClient.MainWindow.GetActions() 場所 C:\Users\User\Documents\Source\xibo-dotnetclient\MainWindow.xaml.cs:行 1010
場所 XiboClient.MainWindow.HandleActionTrigger(String triggerType, String triggerCode, Int32 sourceId, Point point) 場所 C:\Users\User\Documents\Source\xibo-dotnetclient\MainWindow.xaml.cs:行 1107
場所 XiboClient.MainWindow.MouseInterceptor_MouseClickEvent(Point point) 場所 C:\Users\User\Documents\Source\xibo-dotnetclient\MainWindow.xaml.cs:行 242
場所 XiboClient.Logic.MouseInterceptor.HookCallback(Int32 nCode, IntPtr wParam, IntPtr lParam) 場所 C:\Users\User\Documents\Source\xibo-dotnetclient\Logic\MouseInterceptor.cs:行 94
To resolve error messages identify the exact error then search for specific solutions or troubleshooting steps.
Sure! Here’s a short and simple reply using your keyword:
To resolve error messages, check the logs and make sure all settings are correct. I use **freecine**, and fixing config issues usually solves most errors.
Could you share some more details? When exactly does this occur and do you have a scheduled layout with actions or trigger codes?
