I am trying to update my cms and would like to know what will happen to the monitor screen when I do so
Since we are using it at work, we would like to display a message such as “Adjusting.”
Yes, you can schedule a layout to show ‘adjusting’ on the displays while maintenance is in progress. Additionally, you can extend the interval for how often the displays check for new layouts to download and play when they cannot connect to the CMS
Translation to Japanese
「はい、メンテナンス中にディスプレイに「調整中」と表示されるようにレイアウトをスケジュールすることができます。また、CMSに接続できない場合にディスプレイが新しいレイアウトをダウンロードして再生するまでの確認間隔を延長することも可能です。」
By maintenance, am I correct in thinking that you mean a version update on the server side?
