HTTPS and Grafana Issues in Xibo CMS 4.0.12 on Ubuntu Server 22.04
Xibo 4.0.12
Installation Method
Custom install
Operating System
Ubuntu server 22.04
I’m trying to upload images to the CMS but I get an unknown error
I can’t see anything in Xibo log, but I get this from console:
“The page at ‘https://xibobarbieri.com/layout/designer/153’ was loaded over HTTPS, but requested an insecure XMLHttpRequest endpoint ‘http://xibobarbieri.com/library/’. This request has been blocked; the content must be served over HTTPS.”
We also have a problem when trying to connect to grafana using “Xibo Dashboard Service” we bought the connector and configure it using documentation. We see the dashboard when configuring the layout but when we send it to the screen the dashboard is in black.
We have installed the CMS 2 times but the problem persists.
I contacted Xibo support, we believe that the problem comes from the installation. We tried doing a new installation from scratch using the documentation and we are still getting the same errors.
Be sure that your server has all those verbs allowed:
“GET,HEAD,POST,DELETE,PUT”
Otherwise you will not me able to upload nothing to your CMS.
Are you using apache, iis or any other web server?
Check those verbs there and comeback here with what you got.
