In short
- I need help on using swagger UI to testing xibo apis.
- How to setup fill in my swagger ui in xibo-cms\lib\Entity\Application.php:$redirectUris?
- Or, how to code the swagger ui doc to follow the practice in
xibo-cms\cypress\support\commands.js- I can only change the scheme type to
client_credentials. But, I have no clues on filling in rest of the arguments in swagger ui
Detail
- There is no implementation for method
optionon/api/authorize/access_tokenwhich is mandatory on swagger ui page- ref: web/api/authorize/index.php
So, I fill in my implementation for that
$app->options('/access_token', function (Request $request, Response $response) use ($app) {
$httpResponse = $response->withStatus(200);
return $httpResponse;
I noticed that you guys are trying to use Swagger/SecurityScheme to gain the access_token? for rest of the API.
- ref: xibo-cms\lib\routes.php
But, I still cannot gain
access_tokenvia theAuhtorizebutton- I follow guide here to create the client_id & client_secret as requested
- I got this error from authorize
{"error":"invalid_client","error_description":"Client authentication failed","message":"Client authentication failed"} - See below screen captures for further investigation
The request from swagger UI looks like below, which does not include the client_secret
- It fails on
- xibo-cms\web\api\authorize\index.php
- $authRequest = $server->validateAuthorizationRequest($request);
- and finally fail on xibo-cms\vendor\league\oauth2-server\src\Grant\AbstractGrant.php
- $validator->validateRedirectUri($redirectUri)
- Due to my swagger uri is not a xibo-cms\lib\Entity\Application.php:$redirectUris
