I want to register the display directly before the client login but I don’t know how.
What is the use case here please?
In any case, you can call register display directly, same as with other xmds calls - https://xibo.org.uk/manual/en/xmds.html
I’m not yet a wsdl pro but I’m trying to run the registerDisplay method directly in postman for testing.
I write in the URL {{url}} / xmds.php? v = 5 & method = registerDisplay but Bad Request.
what should I add to complete the application.
after, i will create an interface that will drive xibo deported.
hello, everything is ok.
I find what I need and thank you for your answer Peter.
