Hi All,
Similar to my other topic,
Here I’m using the API to update dataset which is used in the DataSet View.
However I still haven’t figure out what is the correct format to set the following columns ;
let’s say the columnIDs are 1 and 2,
what is the format used to pass ID 1 & 2 into dataSetColumnId parameter?
I’m using python to trigger the API.
