- CMS Version : 4
- Player Type : Windows
- Player Version: 3
Question
Hi, I’d like to tag each display with a storeid and name and then use those tags in the display output. I tried adding [[storeid]] to text content, but that did not work.
- Is the tag embedding on the text module something that works and I’m missing it?
- Can I embed the tag in another element like “Webpage” or rss? http://example dot com?s=[[storeid]]
- Can I pull the tag or folder name from javascript using the “Embedded”
- Should I look into some other way of telling the device what data to use based on some other attributes? Folder Name, Display Name, etc.
