I am new to XIBO and I find it very versatile and it seems fit our needs perfectly.
I have a question about Layouts.
I have managed to schedule a Campain that contains three different Layouts that contains different Regions that loads different types of Media.
So far so good.
But I find that the Layouts take too long to load on the Displays.
I want the regions in the layout to show instantly but now it loads and shows one region at a time so on layouts with many regions it takes up to 2 seconds to show it completely.
I have tried to keep down the media size and it works with images but not with a layout containing a region with Forecast IO and one region with a clock.
It first loads the background color and then after approx. half a second the weather and time are displayed.
It also takes some time loading a flash animation that is only 428 kB in size.
It does not matter if the flash movie is part of other media in a Layouts timeline or in a separate Layout.
The flickering when loading the media is very annoying and might be a reason for us to search for another solution than Xibo.
Each set of “web content” - be it flash, weather, text, tickers, etc need to load an instance of IE to display the content. It is most likely the case that IE is taking a long time to load on your system.
If you open IE outside of Xibo do you notice excessive loading time, perhaps lots of plugins, etc?
