Xibo CMS 2.3.10
Installation Method
Custom Install
Operating System
Ubuntu Server 20.04 LTS
Hi to all!
This is a post only for explain the solution to a problem that I don’t found it any valid and updated information about. Please move this topic to another if you consider that here isn’t correct.
We are installing Xibo CMS 2.3.10 in a Ubuntu Server 20.04LTS with Xampp 7.3.7.0.
In the process we need to activate, as a Xibo requirement, the ZeroMQ Extension, but this is not easy in Ubuntu, and for Xampp it’s very worse.
Then here is the step by step that i need to document for find the solution:
1.Install needed packages:
apt install -y net-tools smbclient unzip autoconf pkg-config libzmq3-dev libtool make build-essential
Note: net-tools, smbclient and unzip are optionals, but i used to configure through ssh.
2.Install Xampp (Version 8 and upper it’s not compatible with Xibo CMS at the moment)
3.Download and Unzip php-zqm-master
4.Cd to to folder php-zqm-master
/opt/lampp/bin/phpize
./configure --with-php-configure=/opt/lampp/bin/php-config
make && make install
5.Copy version libstdc++ of Ubuntu to Xampp
find / -name “libstdc++.so.6*”
cp /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.X /opt/lampp/lib
cp /usr/lib/x86_64-linux-gnu/libstdc++.so /opt/lampp/lib
Note: Where “X” is the version with de "find result"
6.Add to Xampp php.ini the extension
vim /opt/lampp/etc/php.ini
extension=zmq.so
7.Restart Xampp
Note: If you see an MySQL Error stopping no worry, restart again.
8.Unzip Xibo CMS in /opt/lampp/htdocs
9.chmod 777 -R to xibo directory
- Apply the steps offered by Xibo Offical Documentation: https://xibo.org.uk/docs/setup/prepare-your-environment
I hope it helps you!
