i really need need some help and instruction on how to install xibo cms self host with database etc on windows 10
Hi Christopher, have you looked at the installation instructions here? I can tell you that from my experience, though it may seem a bit daunting at first if you have little to no Docker knowledge/experience, that option really is the way to go. Xibo does suggest that you install on a Linux OS if possible. There is a community forum on installing with Docker for Windows 10 64-bit, but it’s no longer supported by Xibo.
