we are testing a API from postman in that we found it’s is asking the access token code
we are trying ton achieve to change the layout through postman Api
after one hour completion it will not work because it shows the error that access denied and we you generate again and again from access token api
this is our present situation
As I believe I’ve already told you over support tickets, you can either send access_token call with every other call in your script or use our oauth2 wrappers that should simplify this process - as well as other API calls.
I do not know what you’ve done so far and why use of wrappers is proving to be difficult, as you haven’t exactly tell us that yet.
client_credentials doesn’t support refresh_token because there is little point - it is sufficient to re-call the original access_token request.
If you are making requests through the XiboEntityProvider it will check whether the current access_token has expired before making each request - and if it has, request a new one for you immediately.
If you are using the Xibo provider directly, you will need to test the access_token yourself and provide it to your request.
refresh_tokens are only applicable when using other grants which require user authorisation before granting the original access_token
