How to edit playlist editor from code
How to edit playlist editor from code?
As i researched for a bit there is a folder cms/ui/
there i see playlist editor but when i change anything it does not show in ui, do i have recompile all the js after any changes? Thank you
Hi Paul, after modifying JavaScript files, you need to recompile the frontend assets for the changes to take effect, then refresh the page.
