How To DSCS95 NTP settings?
We are using DSCS95 and i just need to change NTP settings to use internal NTP server.
I didn’t saw Terminal or SSh activation. Is there a way to fix this ?
Thank you
Hi Loopox, welcome to the Xibo community!
I have contacted the hardware team about this and they confirmed that they would suggest using clockSync app for the DSCS9X and DSCS95., Please note that this is the same app recommended for use with the now discontinued DSCS9.
Thank Dan for your Express answer. I will install it and let you know if it solve my problem.
Thank you
Excellent ! It works ! many thx
adb shell settings put global ntp_server 10.80.96.16
