How to connect and interact with an existing website?
Hello folks,
today I started my first layout. My idea was, to create a layout that consists of 8 buttons which can be used interactively. Every time you push or click one of them, you should land on a certain part of our website. To get this done, I created another layout with one region where a webpage widget is configured and when you push one of the buttons you get redirected to the next layout. My question at this point is, is this the way you should do it, or is there a better way.
The next thing is, I don’t want that you can click / touch to much on the website you get redirected to. It shouldn’t be possible to click your way back to the root site of the website or to use any of the existing links.
Hope you can help me.
Best regards
MaFu
