Dear Team
I done Installation and configuration Xibo CMS with CentSOs Apache
and I Create Layout with Video Content
working perfectly but the issue is My Android player taking too much time for content downloading
my File download mode is OFF
then i change to Apache mode
I installed mod_xsendfile in my server
and i edit my httpd.conf file like this
XSendFile on
XSendFilePath /xibo-library/
then restart my Apache
But Then I Try New Layout with Video File but unfortunately Nothing Happen
I miss some setting please guide me.
I notice
when i change to download mode is Apache then my display static showing huge Get File Bandwidth
From the CMS side, setting Apache as the send file mode is all you need to do, it just sets the response headers for Apache to take over delivering that file.
Sendfile isn’t specific to Xibo, so it might be better to have a search for Apache and Sendfile generally?
@dan should this be added to the installation documentation for Apache/IIS. I do not see it mentioned in there and I struggled my way through this for the last couple of hours before seeing this post.
A standard installation (non-docker) comes with sendfile mode switched off, so that files are delivered via XMDS/PHP instead.
When you did your installation, did you have problems with sendfile mode switched off, or are you saying that when you switched it on you had trouble configuring Apache for it?
