How send instant message on xibo cms
Hi how to send instant scrolling message on xibo cms
You create a new layout with your scrolling text on it, then add that layout to the schedule with the priority box ticked.
Next time the Player collects new data from the CMS your existing layout will stop running and your text message will show instead.
Dear Sir,
Thanks for your replay .I have small clarification.can we set player setting to collect data immediatly.That means same time
You can set the Player to collect every 30 seconds but no more frequently than that.
With 1.8 and XMR you’ll be able to set it so the Player collects as soon as you make changes to the schedule.
Sir
Where in client we can set the interval in to 30 sec
In CMS
’Display settings’ page -> edit display profile that your device is using -> adjust collection interval
