How i can solve issue of overlapping of sorting icons on labels in Library
Dear Alex / Dan hi
i am using xibo1.6.4
How i can solve issue of overlapping of sorting icons on labels in Library .
Thanks & Regards
Sachin Jadhao
Mumbai,(Bombay) India (Bharat),
Dear Alex / Dan hi
plz look on my issue also.
1.6.4 is no longer actively developed. 1.7.4 is the latest stable and if there’s still an issue there, let us know and we can get it logged as a bug.
Dear Alex But i am developing 1.6.4 so plz tell me
where exactly table Header Name and Sorted Icon you Merge.
only there is need to small add space between them.
So Plz guide me in this regards
Dear Dan
Plz Guide Regarding My issue
at least tell me in which form merging of Table Column and Sorting Icon Done
The icons are applied by the jquery tablesorter plugin so you won’t find them in the code… the CSS files for that plugin are here
