How can i use one Display for XIBO and another content at the same time?
Hello!
I have the following problem:
Situation: PC at a cash desk, a monitor for employees, a large monitor above the cash desk for customers. This customer monitor is intended to play Xibo, but also serve for presentations. (For example catalogs as PDF or manufacturer B2C websites).
My current attempt:
Ubuntu 14.04 with a Virtualbox => Windows7. VB on the big monitor and the other programs I can then simply push over the VB. Now after about 100000 attempts with the VB, with which the Xibo client runs only very slowly, I find the bug that the client does not run on VB: - (((
Is there another idea, so I can use the large monitor for both functions?
Thank you for your ideas!
Thomas
Problem solved!
With Wine it works under Linux synonymous not XIBO to get to running, therefore a try with Win10 and virtual desktop that has worked. Linux would have preferred me in terms of security, but you can not have everything :slight_smile: Kind regards Thomas
