I’m using an HLS stream to stream the France 24 channel. The channel just changed its address, and since then, Xibo no longer displays the stream (black screen). The stream works from VLC, but Xibo doesn’t seem to support it. Do you have any information on this? I can share the link privately if needed.
Thank you for your help.
Hi @luhut, could you please send me the HLS link via direct message so I can check further? Thanks!
Hi Nadz,
Sorry but i don’t find option to send you direct message on this forum.
Do you have other option to send the link?
Thank for your help.
Hi @luhut, can you try again? You should now be able to see the Message button.
Thank for your support but for the moment i don’t have it. I’ve basic badge but no private message access
Hi @luhut
Thanks for your patience while we looked into this.
After investigating the issue, we found that the stream provider has certain restrictions in place that can block playback depending on how the video is requested. In some cases, streams that work normally in a browser may be blocked when loaded through a widget. Specifically, requests made via JavaScript can sometimes be denied if they don’t meet the provider’s expected criteria, such as required headers.
This can result in the stream working in some environments but not others, even if the setup appears correct.
We’re still exploring options to see if there’s a reliable way to support this kind of stream consistently. We’ll keep this thread updated as we learn more.
Hi @Nadz
Thanks for your investigation.
I stay connected
