Hello!
I’m using Xibo 4.0.2.
I remeber that in 3.x versions you could edit the HTML on “static template widgets” that already came with Xibo, namely weather widgets. I don’t find such option in 4.0.2. Was this option removed?
Additionally, if I just insert a weather icon, I can I make it to show only the current day icon?
Thank you so much
