I am testing the player on a fire stick computer. It works fine, except it doesn’t work vertically.
Do you know how it can be configured for which room in this orientation?
Thank you.
Please see our FAQ here: https://xibo.org.uk/docs/setup/can-i-use-portrait-displays
Thank you
Thank you.
I’m afraid that the device I’m using is a Fire Stick and I would say that in the configuration it allows it vertical.
Thank you very much for the reply.
Hello, where can I buy the equipment in the post that you have indicated to me?
I can’t find any available Minix Neo.
The Minix Neo’s are legacy devices that we have previously recommended and would therefore highly recommend the newer devices DSDevices DSCS9 available from the Xibo shop and DSDevices DSC-J18 available from DSDevices.com.
