Since changing to R101 and using CMS 1.8.1 it has been very hard to keep players running. We are constantly needing to manually clear the players cache and reconfigure the XMR key. Our players stop showing our main layout twice a day. Also the options to send commands to the players are ignored.
Here is the log from one of the players:
2017-04-29 11:32:13 - ERROR - Unable to report media inventory: handshake error: ssl=0x96f19968: I/O error during system call, Bad file number
2017-04-29 08:52:21 - ERROR - XMR unresponsive, issue reconfigure.
2017-04-29 08:47:21 - ERROR - XMR unresponsive, issue reconfigure.
2017-04-29 08:02:19 - ERROR - XMR unresponsive, issue reconfigure.
2017-04-29 07:57:18 - ERROR - XMR unresponsive, issue reconfigure.
2017-04-29 07:20:01 - ERROR - XMR unresponsive, issue reconfigure.
2017-04-29 07:15:01 - ERROR - XMR unresponsive, issue reconfigure.
2017-04-29 01:45:01 - ERROR - XMR unresponsive, issue reconfigure.
2017-04-29 01:36:59 - ERROR - XMR unresponsive, issue reconfigure.
2017-04-28 23:45:01 - ERROR - XMR unresponsive, issue reconfigure.
We have no idea why the players stop playing the main layout, as nothing seems to be logged to say anything else. I will turn on auditing for one of the displays and see what we get back.
So far nothing in the Audit logs show any errors. I can privately share those if needed. Generating about 1300 log entries in 5 minutes.
We removed a layout that contained two forecast.io widgets on two different regions. This along with a overlay layout were displaying fine. However when we removed the layout with forecast.io, our main layout began to play fine. Still we see no errors about playing the layout in the CMS log or on the displays.
We will continue to monitor the problem, but we are not sure were to look for the problem. As it stands right now it looks like some issue with the forecast.io module and widgets.
