GET /displayProfile API seems to be broken - 1.8.0-alpha2
I am trying to get the Display Profile by calling the REST API as documented in Swagger Docs:
GET http://myXiboserver/displayprofile
but get an “Unexpected Error, please contact support.” error as response.
In server logs I see:
Named route not found for name: displayProfile.edit.form#0 /var/www/html/xibo/vendor/slim/slim/Slim/Slim.php(1087): Slim\Router->urlFor(‘displayProfile…’, Array) #1 /var/www/html/xibo/lib/Controller/Base.php(131): Slim\Slim->urlFor(‘displayProfile…’, Array) #2 /var/www/html/xibo/lib/Controller/DisplayProfile.php(95): Xibo\Controller\Base->urlFor(‘displayProfile…’, Array) #3 [internal function]: Xibo\Controller\DisplayProfile->grid() #4 /var/www/html/xibo/vendor/slim/slim/Slim/Route.php(173): call_user_func_array(Array, Array) #5 [internal function]: Slim\Route->Slim{closure}() #6 /var/www/html/xibo/vendor/slim/slim/Slim/Route.php(468): call_user_func_array(Object(Closure), Array) #7 /var/www/html/xibo/vendor/slim/slim/Slim/Slim.php(1357): Slim\Route->dispatch() #8 /var/www/html/xibo/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call() #9 /var/www/html/xibo/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call() #10 /var/www/html/xibo/lib/Middleware/ApiAuthenticationOAuth.php(58): Slim\Middleware\MethodOverride->call() #11 /var/www/html/xibo/lib/Middleware/State.php(102): Xibo\Middleware\ApiAuthenticationOAuth->call() #12 /var/www/html/xibo/lib/Middleware/Storage.php(39): Xibo\Middleware\State->call() #13 /var/www/html/xibo/vendor/slim/slim/Slim/Slim.php(1302): Xibo\Middleware\Storage->call() #14 /var/www/html/xibo/web/api/index.php(95): Slim\Slim->run() #15 {main}
I tried setting the displayProfileId, name and type parameters as well without success. I am not sure if it’s my misunderstanding or is this really broken.
Also does not seem to work in Alpha 3. Same result.
Thanks, recorded as a bug:
