fwc
1
Does anyone know how to edit the Weather layout (JSON file I believe) to display the 5 day weather forecast vertically?
I want to show weather on the right side of the display in a narrow region and then content on the left side.
Has anyone done this or know how to do this?
Thanks!
You can change the HTML/CSS of the template to fit whatever you need.
Peter
4
As it is (1.7 series) you will need to edit the CSS by yourself.
In 1.8 series there will be a lot more templates to choose from, including some more vertically friendly ones.
fwc
5
Thanks and understood I need to edit. Can you point me to any guidance or documentation? I’m not very familiar with JSON at all.
Thanks!
