Forecast IO problem
First of all, thank you for the help on my previous topic it worked really well !
Unfortunately, I have a problem with Xibo concerning the display of the Forecast Module. I think I have done everything I should have for it to work properly but it doesn’t.
After installing the module, i registered to have the API Key but still, when stting up the module, i can’t have it displayed, it tells me that “No data returned, please check error log.”
Unless I didn’t look in the right place, my error log is empty.
Is there anything I did wrong ?
Thank you in advance !
Marine
Pleas turn on Auditing and run Verify All on the modules page. If it still does not work, try looking at this
okay I will try that ! Thank you
This topic was automatically closed 2 days after the last reply. New replies are no longer allowed.
