I added forecast ıo on my layout and I can view. But when I selected French in supported language and I re-run layout, forecast ıo’s language was English. Forecast ıo application supported this language.
Try to create an embedded HTML, and paste the link that you have generate at the end of the page.
http://www.tameteo.com/widget/
It’s look like Forecast IO but it’s the french version, and an other view.
