Additionally, when I try to get other Weather Templates to display they work in the Preview Layout, but do not display on the player at all. I checked the logs and have not found anything out that seemed to be an error.
Got around it for now by coping the font files from “xibo\modules\theme\forecastio\weather_icons” to the library manually then adding the following to “Enter the template for the current forecast. For a list of substitutions click “Request Forecast” below.” when overriding the template:
@cslaughter It’s great that it’s working like that for you, but we strongly recommend that you don’t have your Xibo CMS library in a web accessible location. The only access to those files should be via XMDS.
If you look at your Player status, are the weather webfont files being included in RequiredFiles correctly?
I had to manually copy the following files form the Server c:\xibolibary\ to the Player Client c:…xibolibrary\ in order to get the icons to show up on the player side:
