Font sharing and Layout Bug
I have users in with access to a Folder. The can create and delete Layouts. But inside the Layout they cannot delete a widget. This is the “users” group:
The second Issue: They can select a Font in the Editor. But in the preview it shows the Font only if the following right is set:
It is also in 4.0.14
@dan maybe you didn’t see this Bug :slight_smile:
