I installed 1.7.1 client on my new recovered pc(windows 8.1 64 bit), the CMS version is 1.7.1
I set default browser as CEF.
The webpage is working very well, but when I was testing some embedded medias, it could not load plugin.
So I installed NPAPI. Then the embedded medias worked.
After the installation, I tried testing the webpage again, the Xibo Client always stopped after about 10-20 minutes, no exception, just quit. I reported this issue in Github #240.
1 open chrome browser, type about:plugins, and found the adobe flash plugin ppapi and disable it, then open a webpage which has embed flash, when it prompt to upgrade flash plugin, click it, then ppapi, npapi will be installed, and go back to chrome browser, enable disabled flash plugins.
2 go to adobe flash official download website https://get.adobe.com/flashplayer/
click " do you have different operation system or browser?"
then choose your operation system and select pp 17 for firefox - npapi
download and install.
Yes, Alex, I totally agree with you. I have another machine running the test with IE, it’s stable.
For CEF, is it possible to try with a 64 bit cef lib as I said in #240? I tried it on 1.7.0, it solved this stop issue, but I got an exception after about 24 hours from xilium ( invoke function). Maybe I will try again after I finish testing 1.7.2 IE version.
I tested this issue last week on 1.7.2, the webpage works fine. No problem found after I installed npapi.
Usually I test webpage with aol, there was a video always running on that website, but last week, it was replaced by an image (weekly flyers). That’s the obvious difference I found, I don’t know if there were any other changes made on that website.
1 1.7.2 on both server and client side, client OS win8.1 64bit
2 create a profile, browser=cef
3 install npapi
4 create a webpage and host it, the code is as the follows
5 create a layout with media type webpage
6 schedule it
7 xibo stopped after about 10minutes
CEF is not getting much airtime at the moment because it is very buggy - I haven’t been able to make it run reliably and realistically a lot more time needs to be spent on it tuning the integration.
Our time at the moment is being directed into other areas.
Your debugging is of course valuable, but I can’t guarantee that we can look it at in the short term.
