Could you provide new feature regarding to assign layout as below:
- Add a menu inside the layout designer area, to set on the Displays listed. Hopefully, with this feature users can assign and unassign layouts from any of the listed Displays they own
- Add some sort of search filter in the Assign-Layout menu in the Display menu, so that the user can distinguish which Layout needs to be assigned
Thank you
