Even when running the task “Fetch Remote DataSets” nothing is updated in the datasets data, it works pefectly fine when testing the data and the correct json is showing.
We have about ~40 connections to airtable to datasets in xibo, could this be something bothering the speed of updates? Because sometimes it does update, only couple of hours later.
The datasets are in layouts that are running on a display.
I get the feeling that it started to slow down when we updated to 2.1.0 but i could be wrong.
Please help us sort this out,
Frank
