Hello, so we bought Cloud and Android pack to test the system and we’ve been quite satisfied with it, so we would like to expand the system. We plan to centralize all the devices in our cloud server.
Question: If we wanted to expand our infraestructure, should we buy more Cloud and Android bundles or just Android licenses since we already have a server? If we just buy Android licenses, can we expand the server separately?
If you’re using Xibo Cloud, then you’ll need to buy additional display slots for your existing CMS instance, and some more Xibo for Android licenses that’s correct.
You can’t use the bundle option because that will create a new CMS which probably isn’t what you want to do.
To be clear, in case there are confusion with terms.
Xibo CMS - free, open source, download and run on your infrastructure, no charge
Xibo Cloud - hosted Xibo (exactly the same software, but we run it for you). You need 1 slot per display, so inside your xibo.org.uk customer account, you go to your Android Licence pool and add a licence, then you go to your Cloud CMS and add a slot, then checkout.
