Bonjour,
suite à l’évolution du xibo server 1.6 à 1.7, j’aimerai transférer les mise en page faite sur Xibo 1.6 comment procéder ?
Following the evolution of xibo server 1.6 to 1.7, I would like to transfer the layout made on Xibo 1.6 how to proceed ?
If you will update your CMS (and remember to make backups!) then after upgrade your layouts will still be there - they (their format) might need to be updated, but that can be done from the web ui after upgrade.
For upgrading instructions, please see this manual page - http://xibo.org.uk/manual/en/release_notes_1.7.9.html
Or is your 1.7 a completely fresh installation?
Yes, this is a new installation, I installed version 1.7 on a new server
And I would like to be able to recover the layouts of the old server 1.6
