Every Layout invalid
I have installed the Xibo player on my Android 12 device, connected to the CMS, licensed, authorised etc. Unfortunately I am seeing errors in the status that all layouts are invalid. The layout is just a full screen logo image and nothing else, so I don’t think it would be invalid.
How can this be debugged? I have already checked the “verify modules” procedure which didn’t make a difference.
Check the resolution of your content, and check if your device is able to show it…
Some android devices have some problems by showing 4K images, for example…
Also, check your logs menu, may you can get more information there
Let us know how it works
