Quello che segue è l’errore che si presenta quando cerco di installare XIBO. Ho seguito i consigli di DAN inserendo – all’inizio delle linee 670 671 672 di structure.sql
An error occurred populating the database. Statement number: 57. Error Message = [SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'ADD CONSTRAINT blacklist_ibfk_1
FOREIGN KEY (MediaID
) REFERENCES media
(m' at line 1]. File = [Array]. SQL = [ADD CONSTRAINT
blacklist_ibfk_1FOREIGN KEY (
MediaID) REFERENCES
media(
mediaID), ALTER TABLE
campaignADD CONSTRAINT
campaign_ibfk_1FOREIGN KEY (
UserID) REFERENCES
user(
UserID`)].
