Error message when start up xibo jit
hello guys,
i am testing a lot with xibo . now i finally have a good windows pc. and starting up ik get the next error
Please can someone help me
grts
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at XiboClient.Media.SignalElapsedEvent()
at XiboClient.Media.timer_Tick(Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.34209 built by: FX452RTMGDR
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
XiboClient
Assembly Version: 2.0.0.0
Win32 Version: 2.0.0.0
CodeBase: file:///C:/Program%20Files/Xibo%20Player/XiboClient.exe
System
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Xilium.CefGlue
Assembly Version: 3.0.0.0
Win32 Version: 3.0.0.0
CodeBase: file:///C:/Program%20Files/Xibo%20Player/Xilium.CefGlue.DLL
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
XiboClient.XmlSerializers
CodeBase: file:///C:/Program%20Files/Xibo%20Player/XiboClient.XmlSerializers.DLL
System.Web.Services
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Web.Services/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
Microsoft.GeneratedCode
Assembly Version: 1.0.0.0
System.Management
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
Xilium.CefGlue.WindowsForms
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/Xibo%20Player/Xilium.CefGlue.WindowsForms.DLL
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Can you provide more information about the client PC? OS, version of Xibo client, etc.
Windows 7 starter
Xibo 1.7.3
32 bits pc 1 gb ram
On a 32" monitor
I am getting the same sort of error. CLIENT 1.7.3 .NET framework 4.5.2, Windows 7, Intel Core 2 Duo, 2gb ram. Error occurs after the player has been up and running for a few hours.
at XiboClient.Video.timer_Tick(Object sender, EventArgs e)
mscorlib
XiboClient
System
Win32 Version: 4.0.30319.34238 built by: FX452RTMGDR
System.Drawing
Xilium.CefGlue
System.Xml
Win32 Version: 4.0.30319.34234 built by: FX452RTMGDR
System.Web.Services
System.Management
AxInterop.WMPLib
CodeBase: file:///C:/Program%20Files/Xibo%20Player/AxInterop.WMPLib.DLL
Interop.WMPLib
CodeBase: file:///C:/Program%20Files/Xibo%20Player/Interop.WMPLib.DLL
enabled.
For example:
