I exported 4 small layouts successfully, but then went to export some of the larger layouts containing an hour of twelve different video’s. Now I get a 504 Gateway error though Nginx.
I’d prefer not to create every layout every Christmas season. What kinds of things need I check to resolve this?
Error 504 is gateway timeout - so it’s taking too long to build the layout export. If you control the server you can try increasing your php max execution time, and your nginx timeouts to give the system longer to build the zip file.
