During the upgrade to 1.8, I we run into “Unexpected error, please contact support”.
This happens at step 90: Add XMR Columns to the Display Table, which is the first step of 1.8.0alpha2.
If I look at the MySQL database after seeing this error, I can see that step 89 has been applied to the DB, and that step 90 (which throws the error) has not. I’ve also learned that I can apply the SQL from step 90 manually without error. This doesn’t cause the upgrade to proceed, though. I’m not seeing PHP errors in the log.
If you’ve applied the SQL from step 90 manually and it hasn’t errored, then assuming you have backups etc then it should be safe enough to skip the step and allow the upgrade to continue.
I forgot to mention this in the original post, but I’ve tried that as well. Nothing seems to happen when I click “Skip this step”; I can’t see how to get it to move to the next step.
Just to add my experience to this, the “skip this step” button didn’t work for me either when I was testing the upgrades from 1.7.9 to both 1.8.0 rc2 and rc3. It wasn’t possible to skip the steps.
I’ve had a chance to generate some Xibo logs and take a look at exactly what’s happening, and I’ve found a klugey workaround.
What was happening was this: As soon as the 1.8.0-alpha phase completed, /clock started kicking off install Fonts called with options....
This leads to the PDOException mentioned above, because the it uses the column “released” which does not get added to the table “media” until several steps later.
I moved the step that updates the “media” table to the file associated with 1.8.0-alpha, so that it is completed before 1.8.0-alpha2 starts. To be precise, I moved (inserted) lines 57-60 from /install/steps/121.json to line 361 in /install/steps/120.json. The installation appears to have been successful after this change.
This definitely seems like a bug because the application is trying to do this operation before the database is ready.
If the upgrade takes time, /clock will kick off and fail as you have indicated - in fact a bunch of things might do so (such as players connecting, maintenance, etc). That in itself isn’t really an issue as those things will start working again once the upgrade has completed.
Upgrade steps are inserted into the update table and run in sequence. Skip this step marks the step in the upgrade table as “skipped” and should move on.
I wonder if there are certain circumstances that mean “skip this step” actually encounters an error when trying to run - which would explain why it wouldn’t work.
The application stack expects that column to be there in DBVersion 125 and above. So the question is - what is your DBVersion if you look in the version table? If you’re stuck at a step in 1.8.0-alpha2, then the DB version should still be 120.
"step": "Add released and api ref to media table",
"action": "ALTER TABLE `media` ADD released tinyint(4) NOT NULL DEFAULT 1, ADD apiRef varchar(254) NULL;"
from \install\steps\121.json into \install\steps\120.json.
Hmm, I am at a loss in that case - ill run through some more tests to see if I can work out what was referencing that column. The only obvious place is commented out for anything lower than 125.
I forgot to mention that if you are able to provide your DB backup from 1.7.8 we’d be happy to run the upgrade in a test instance and try to locate the issue that way?
The only way we can progress this issue (and related issues) is with a full backup of a 1.7.xx CMS installation database that exhibits the issue.
If anyone has one, without confidential information, then please do send it over and we will run through the upgrade ourselves to investigate the issue in detail.
