Enable ZeroMQ IIS
How do I enable ZeroMQ for xibo cms 1.8 rc2 on IIS?
You can download the latest extension from here: http://windows.php.net/downloads/pecl/releases/zmq/
And then look at the Windows instructions here: http://zeromq.org/bindings:php
I’d recommend you consider using Docker, as that is the supported method going forwards.
update links for windows instructions
http://wiki.zeromq.org/bindings:php
