My dynamic group scheduling does not affect the player.
I reverted to normal group and it works.
The group are :.+ (for all players) and .±U (for players with name finishing in -U)
I have schedule in both, but as soon as I set them as dynamic the layout is removed from the player schedule.
I use the docker image installation and my task (Regular maintenance) is indicated to have run as schedule (every 5 minutes).
I did wait for 2 hr before setting the group manually, it the task in the daily maintenance or the regular maintenance ?
I think I have a key element
I try with a brand new group and it work, so I try again with my manual group (that have display) and change it to a dynamic group and this one did not work.
I think this is the key aspect the fact that the group was a manual group with membership before.
Is there a way to know what is the scedule result in the CMS ?
It will help a lot with testing
