is there a plan or possibility for implementing a LTE module in the DSDevices DSCS9X?
A SIM card slot is already there.
Thank you,
Zoran
Thank you,
Zoran
It is actually a MicroSD slot. For restoring Android firmware (if you don’t have the USB-A cable)
Okay, thanks for the new information. Maybe I should check the manual. ![]()
Never the less, is there a plan for a LTE variant?
