Hi all,
I have purchased a DSCS9 just two days back. I want the screen to be installed vertically. Hence I need to rotate the screen. How can I do that . I have created a portrait display profile. Pls guide me how to configure it in the android device.
Assign your new Profile by going to the Displays page in the CMS and editing the display to assign.
You may need to turn off Surface View in the Display Profile on the Troubleshooting tab, as some videos may look pixelated.
You will also need to go into the DSCS9 settings app and go to Display>Screen Rotation Display and set that to original as It currently defaults to middle port which should be addressed in the next firmware from DS Devices.
Natasha, can you elaborate on the DSCS9 settings?
I have the same issue and I was able to create a new profile, make it Portrait and assign the displays to that profile.
However, the image did not rotate on the display.
I am unable to find the “Screen rotation display” under the “Display” in the settings. There is no option like that, or I’m looking in the wrong place.
