Dear XIBO community
Just to be sure, I wanted to ask a question about screen rotation… horizontal, vertical, etc…
I’m using DSCS9X with player android 3-306 on the server Version 3.3.4. The options listed here should work?
because we tried, with a reboot but it is still in horizontal, we wanted use horizontal reverse
thanks
francesco
natasha
October 16, 2023, 12:13pm
2
Hi, the DSCS9X Player supports normal orientation, 90 or 270 degrees rotated but not upside down.
try the orientation on the DSCS9X settings to see if this helps.
thanks, in that way it works for some time
but if the DSCS9X restart (shutdown and boot), it goes back to normal orientation
Hmm,
I have one display (DSDC9X) running at on of our customer, it using 270’degrees option, so vertical inverse and this is working properly. Have you tried to do this on a different player?
