Hello my friends I have a problem with xibo, Doesn’t appear in Storage Options my SD Card. I don’t know why. Please can you help me and tell me what happen. Thank you so much for your help.
What version are you using please?
Hello I am using the last one the version 1.7_R62. Thank you for your answer.
Then if you go to Xibo for Android settings, enable public storage, you should be able to select sd card in storage options.
Yes, but the option of sd card doesn’t appear. Can you see a picture??
