Docker xibo cms develop not working
Hello there !
I need some help with the docker install of xibo-cms-develop version 4.01 on windows. When i try to follow the simple path as it’s mentionned on your tutorial, the localhost response is all the time 500, like something is missing.
However, i download the folder on your website and also on the official github.
When i try to use the xibo-docker-master it works perfectly but the yml file on xibo-cms-develop seems to be not working for me.
When i try to mix both and set up the docker-compose.yml of each folder it show me an other error: “The CMS is temporarily off-line as an upgrade is in progress. Please check with your system administrator for updates or refresh your page in a few minutes.”.
I put the cms_custom_files.yml into the folder but its not working also.
I am sure i am missing something but i dont know
thx in advance for the help
best regards
