Trying to upgrade from 3.0.7 to v4, we have done the upgrade successfully to 3.3.8 but are having an issue completing the upgrade to v4.
docker-compose logs shows these errors after starting the upgrade:
Is there something we’ve missed along the way?
xibo-docker-400-cms-db-1 | 2023-10-05T12:27:16.994421Z 0 [System] [MY-010116] [Server] /usr/sbin/mysqld (mysqld 8.0.34) starting as process 1
xibo-docker-400-cms-db-1 | 2023-10-05T12:27:17.002565Z 1 [System] [MY-011012] [Server] Starting upgrade of data directory.
xibo-docker-400-cms-db-1 | 2023-10-05T12:27:17.002607Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
xibo-docker-400-cms-db-1 | 2023-10-05T12:27:17.043592Z 1 [ERROR] [MY-012209] [InnoDB] Multiple files found for the same tablespace ID:
xibo-docker-400-cms-db-1 | 2023-10-05T12:27:17.043670Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 2 = ['mysql/innodb_index_stats.ibd', 'mysql/plugin.ibd']
xibo-docker-400-cms-db-1 | 2023-10-05T12:27:17.043686Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 3 = ['mysql/servers.ibd', 'mysql/slave_relay_log_info.ibd']
xibo-docker-400-cms-db-1 | 2023-10-05T12:27:17.043691Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 4 = ['mysql/help_topic.ibd', 'mysql/slave_master_info.ibd']
xibo-docker-400-cms-db-1 | 2023-10-05T12:27:17.043695Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 5 = ['mysql/help_category.ibd', 'mysql/slave_worker_info.ibd']
xibo-docker-400-cms-db-1 | 2023-10-05T12:27:17.043700Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 6 = ['cms/phinxlog.ibd', 'mysql/help_relation.ibd']
xibo-docker-400-cms-db-1 | 2023-10-05T12:27:17.043704Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 7 = ['cms/session.ibd', 'mysql/help_keyword.ibd']
xibo-docker-400-cms-db-1 | 2023-10-05T12:27:17.043709Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 9 = ['cms/usertype.ibd', 'mysql/time_zone.ibd']
xibo-docker-400-cms-db-1 | 2023-10-05T12:27:17.043733Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 11 = ['cms/useroption.ibd', 'mysql/time_zone_transition_type.ibd']
xibo-docker-400-cms-db-1 | 2023-10-05T12:27:17.043738Z 1 [ERROR] [MY-012202] [InnoDB] Tablespace ID: 21 = ['cms/lkmediadisplaygroup.ibd', 'sys/sys_config.ibd']
xibo-docker-400-cms-db-1 | 2023-10-05T12:27:17.043755Z 1 [ERROR] [MY-012930] [InnoDB] Plugin initialization aborted with error Failed, retry may succeed.
xibo-docker-400-cms-db-1 | 2023-10-05T12:27:17.043772Z 1 [ERROR] [MY-011013] [Server] Failed to initialize DD Storage Engine.
xibo-docker-400-cms-db-1 | 2023-10-05T12:27:17.044001Z 0 [ERROR] [MY-010020] [Server] Data Dictionary initialization failed.
xibo-docker-400-cms-db-1 | 2023-10-05T12:27:17.044033Z 0 [ERROR] [MY-010119] [Server] Aborting
