Installation Method
Docker
Operating System
Ubuntu 22.04
I have installed the CMS with docker. I modified the config.env with the necessary modification (DB Password, CMS Server name FQDN) . I am not using any special configuration. Then I wanted to start the CMS.
I always ended in an connection problem between the CMS and DB container. I also tried to add the ports to the DB container in yml file. Still the same problem.
ports:
- "3306:3306"
I also tried to remove all data from the shared folder and start from the beginning.
The mysql container is not showing any error.
xibo-docker-334-cms-db-1 | Version: ‘5.7.42’ socket: ‘/var/run/mysqld/mysqld.sock’ port: 3306 MySQL Community Server (GPL)
I always get the following Error in the CMS container:
xibo-docker-334-cms-web-1 | MySQL started
xibo-docker-334-cms-web-1 | Configuring MySQL cnf file
xibo-docker-334-cms-web-1 | ERROR 2002 (HY000): Can’t connect to server on ‘mysql’ (115)
xibo-docker-334-cms-web-1 | New install
xibo-docker-334-cms-web-1 | Provisioning Database
Does anybody know a solution for the problem?
