I’m in the process of installing Xibo using Docker, and it’s almost complete, but I encountered an issue.
When I run docker-compose up -d, I encounter the following error: File “/usr/lib/python3/dist-packages/docker/api/client.py”, line 214, in _retrieve_server_version
return self.version(api_version=False)[“ApiVersion”]
File “/usr/lib/python3/dist-packages/docker/api/daemon.py”, line 181, in version
return self._result(self._get(url), json=True)
File “/usr/lib/python3/dist-packages/docker/utils/decorators.py”, line 46, in inner
return f(self, *args, **kwargs)
File “/usr/lib/python3/dist-packages/docker/api/client.py”, line 237, in _get
return self.get(url, **self._set_request_timeout(kwargs))
File “/usr/lib/python3/dist-packages/requests/sessions.py”, line 602, in get
return self.request(“GET”, url, **kwargs)
File “/usr/lib/python3/dist-packages/requests/sessions.py”, line 589, in request
resp = self.send(prep, **send_kwargs)
File “/usr/lib/python3/dist-packages/requests/sessions.py”, line 703, in send
r = adapter.send(request, **kwargs)
File “/usr/lib/python3/dist-packages/requests/adapters.py”, line 486, in send
resp = conn.urlopen(
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 791, in urlopen
response = self._make_request(
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 497, in _make_request
conn.request(
TypeError: HTTPConnection.request() got an unexpected keyword argument ‘chunked’
How to solve this problem ?
